anyone ever tried to make an airfoil?
Old Sep 24, 2001 | 11:31 PM
monte-ss's Avatar
Car: 87 Monte Carlo SS
Engine: 89 IROC 350 TPI
Transmission: 700R4 rebuilt w/TCI kit
Axle/Gears: 9" from 57 ranchero unsure gears.
Hey everyone I was just wondering if anyone made their own air foil? I was thinking of making one out of fiberglass, kind of like the phenolic carb spacers but a fiberglass or epoxy of some kind that wont fall apart when there are 1000 CFM of air going past it. if anyone had tried without success please let me know, I dont want to experiment with this to find out there is a chunk of fiberglass or whatever stuck in a runner or something like that. Just an idea nothing like the power adder ideas of the leaf blowers on the intake but an idea non-the-less.
thanks guys
Jack
'87 Monte Carlo SS,with '89 IROC 350,700 trans, blew up 3.73 posi stuck with crappy 2.73's neeed gears! hooker headers, flowmaster 2 1/2" exhaust true dualls, recently installed a set of alum vette heads 58cc, new cam for a paxton, recently installed paxton, OMG need a posi bad. Found a guy who can build me a ford 9" (yep sorry guys) for less than 500 then comes all the goodies such as disk brakes so on and so on, will it ever end?? I hope not!!
Old Sep 25, 2001 | 03:31 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
I made one using epoxy putty. I simply put a bolt (~3/8, i forget exactly) in each side while i formed the putty to fill in the cavity. Then i pulled the bolts out to leave the opening for the IAC and breather.
It's been many months (and ~12k miles including lots of hot summer cruising) and no problems so far.
Before i did it i posted the same question and a few other people had tried it too with no problems. Beats the hell out of paying $26 for an SLP unit (or more if you're really dumb and buy a higher priced brand)
Ed Maher - Moderator @ The TPI & Carb Boards
92 Z28 Convertible - Quasar blue / Tan top
305 TPI A4 2.73 - 14.8 @ 93.1
Stock except ported plenum and dual cats
-=ICON Motorsports=-
- Definitely prototypes, high powered mutants of some kind. Too weird to live, too cool to die
Old Sep 25, 2001 | 04:20 PM
breathment's Avatar
you do realize a air foil doesn't do anything until your running 500+ HP. i know, i have one too, but i just thought id share what i'v heard.
- David
88' GTA 5.7L TPI MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT, Flowmaster 80 Series
Old Sep 25, 2001 | 05:03 PM
Ed Maher's Avatar
Car: 04 GTO
Which is exactly why making one for $2 of epoxy putty isn't a bad idea. Paying real coin for one is absurd, i've never heard of anyone getting a real improvement from one. But for damn near free, why not, it's good for a laugh when you show your friends...
Old Sep 25, 2001 | 05:14 PM
breathment's Avatar
good point
Old Sep 25, 2001 | 09:29 PM
monte-ss's Avatar
Thanks ED, I figured it would work, as far as over 500 HP thats a first for me, Ive heard (but thats the problem we always hear this and no one shows if it works or not) that its almost an instant feel or whatever as far as response or torque who knows, it may be one of those things that everyone BS's about like 1/4 times. But for a couple bucks Ill give it a try and I dont usually take off my air system so I wont have to show it off.
Old Sep 25, 2001 | 09:34 PM
Vader's Avatar
Here's your good laugh for today:
Later,
Vader
Justice and Freedom will Prevail
Old Sep 25, 2001 | 11:44 PM
Guest
Guest
Posts: n/a
I was looking at my car one day in 1988 and I decided it needed an airfoil to help the air choose a path on its way into the engine, so I made one out of aluminum with a file, sandpaper, and patience. Didnt even know TPIS existed.
As long as the material you use can handle the heat and vibration, it will be fine. I'd personally avoid fiberglass.
Old Sep 26, 2001 | 12:17 AM
robert1's Avatar
Yeah man, that's like paying $60-$80 for an adjustable regulator when you can make your own for $5!!!????
Old Sep 27, 2001 | 08:15 PM
89Irocz23's Avatar
how do you make your own fuel pressure regulator
Old Sep 27, 2001 | 08:24 PM
monte-ss's Avatar
89, if you do a search on it you ought to find how to do it, if I remember correctly it takes just a 1/4" bolt and nut a little welding and your set, I need to do mine casue my after market one crapped out after I put a paxton on it.
kairles
Oct 26, 2015 09:13 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
86White_T/A305
Aug 17, 2015 12:16 AM
mustangman65_79
Aug 11, 2015 03:17 PM
z28addict8490
Aug 7, 2015 08:48 PM
