CC of stock LB9 Heads
Old Sep 28, 2001 | 09:16 AM
diesel's Avatar
Posted below on what heads for a 305, most seem to be made for a 350. What is the cc of the stock LB9 heads. The World Product ones that were suggested are 58 cc.
I am trying to calculate what the CR would be after they were installed. The stock CR for my engine shows to be 9.3:1 from the tech data section.
Thanks in advance.
Diesel
91 TA 305TPI/700R4
-All stock except SLP 2OTL Stainless Catback System (However, not all stock for long!!)
Old Sep 28, 2001 | 09:42 AM
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
Yep, they're right. I have one of my old 305 heads off and they chambers sure look a good bit smaller than the typical SBC head. Looks like your CR won't change with the WP Torquer 305 heads (assuming that's the one they had suggested).
Greg Westphal
'87 IROC 355TPI/A4
Old Sep 28, 2001 | 10:20 AM
Drakar's Avatar
The 305 and 350 heads have the same chamber, just different size valves. Both are 58cc event the vette aluminum heads are 58cc.
S/R torquers are I have heard the cheapest and best aftermarket head.
IMO
cheap+goodflow>expensive+goodflow
1989 Trans Am GTA, L98 5.7L TPI, TH700-R4, T-Tops, dual cats, 9-bolt rear, 3.27,
- K&N Air Filter
- Dynomax muffler
1992 Camaro RS, LO3 5.0L TBI, T-5, T-Tops, 3.08, L69 Dual Snorkel - Sold
- K&N Air Filter
Honda engines ROCK, I have one on my lawn mower but I still have to push it.
Old Sep 28, 2001 | 10:56 AM
Guest
Guest
Posts: n/a
<font face="Verdana, Arial" size="2">Originally posted by Drakar:
IMO
</font>
Ummmmmmmmm cast iron 350 heads (like on thirdgens) are 64cc not 58.
Old Sep 28, 2001 | 11:11 AM
diesel's Avatar
So what is the concensus?? Are the 305 heads 58CC stock or 64CC stock? Just doing some rough calculations, if they are 64 cc (assuming .050" for head gaskets) and flat tops (???) if the stock CR is 9.3:1, moving to a 58CC will bump CR to 10.4:1.
A pair of the world products SR Torquer heads assembled are going to be right at $750-$800. With a good exhaust (SLP 3" catback now and SLP 1 5/8" headers in the future) and siamesed TPI setup, will there be a noticible difference in performance? Any ideas on a descent cam for this setup??
TIA
Diesel
[This message has been edited by diesel (edited September 28, 2001).]
Old Sep 28, 2001 | 12:56 PM
Guest
Guest
Posts: n/a
All stock 305 heads are 58cc.
Old Sep 28, 2001 | 01:01 PM
Drakar's Avatar
Thanks Madmax, my bad
- K&N Air Filter
- Dynomax muffler
- K&N Air Filter
theshackle
Mar 5, 2017 06:37 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
gta90
Sep 15, 2015 04:00 PM
happyhapka
Aug 15, 2015 04:42 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
