TBI to TPI swap...question on fuel pump
Car: 92'Camaro RS
Engine: a loud one
Transmission: bolted to the engine
I just recently purchased a TPI set up off of an 89 IROC.I am taking the TBI off my 350 and putting this on after i get it cleaned up. My question is, I have the stock fuel pump from the 305 motor that was originally in the car to start with. Will this fuel pump work with the TPI set up or am i gonna have to shell out some more bucks for a new one?
92' Camaro RS/Black,T-tops/350 TBI Targetmaster Comp.engine/5 spd/march underdrive pulleys/hedman hedders/3" dynomax exaust/hyper tech stage 2 chip/3.42 gears/K&N air filter/MSD blaster GM coil
Car: `86 SS / `87 SS
You need a fuel pump for port fuel injection; your sending unit should be the same either way so... get one for a TPI car, and put it in!
jmd
1986 SS with...
86LB9 TPI atop the original L69, hydraulic clutch T5, Energizer 272 cam, chargedair.com fan, Global West CNR-88-C negative roll kit, 89 Iroc front springs, CC635 Moog rear springs and a whole bunch of other fun stuff
jmd
1986 SS with...
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
TBI runs on about 12-15lbs of pressure and a TPI runs on about 42+lbs so you'll need a higher flow fuel pump. http://www.autoperformanceengineering.com/ has good deals on WalPro fuel pumps.
1991 banditt2 #130 of 600
Project 350 TPI Banditt II
http://www.street-dawg-racing.cityslide.com
www.gcfba.com (Greater Cincinnati F-Body Association)
http://www.cincyspeed.com/
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
