roller rockers
Old Sep 29, 2001 | 03:22 AM
TA88GTA's Avatar
roller rockers
I'm going to install edelbrock 6085 heads on my motor and just wanted to know if i have to go with self aligning rockers used on stock heads or can I go with non-self aligning. I want to go with 1.6's. If you could give me some options and P/N that would be great, thanks.
Old Sep 29, 2001 | 07:23 AM
Mike89GTA's Avatar
I'm pretty sure you can use self aligning if you don't use guide plates, or non self aligning with guide plates. When I first had my engine put together they used self aligning ones and I told them to take it apart and use guideplates and non-self aligning ones because it's more stable at high rpms IMO..
4 bolt 350, 10.4:1 Compression, Edelbrock Aluminum Heads 6085, LT4 Hot Cam /w 1.6 full rollers (Crane), Scat Crank, SLP 1 3/4" Headers, SLP Cold Air Intake, Crane AFPR, 48mm TB, ported plenum, stock runners, Accel Super Ram intake manifold, 95Z #24 injectors, stock fuel rails, T5 Tranny, 3.45s, 9 bolt rear, 4 wheel discs, BFG Comp T/As rear, SZ50s in front, Alston SFCs, ES Trans Mount, ES front A-arm bushings, ES front sway bar end links
Old Sep 29, 2001 | 09:19 AM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
chech with edelbrock some aftermarket manufactors cast the heads in a way so you wont need guideplates.
1991 banditt2 #130 of 600
Project 350 TPI Banditt II
http://www.street-dawg-racing.cityslide.com
www.gcfba.com (Greater Cincinnati F-Body Association)
http://www.cincyspeed.com/
KO1
16
Oct 15, 2015 05:00 PM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
92projectcamaro
Sep 29, 2015 07:07 PM
dusterbd
Sep 29, 2015 08:40 AM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
