Ugh ... 34 wont go away
Old Apr 16, 2008 | 09:03 PM
slicef96's Avatar
Car: 1987 Trans Am
Engine: LB9 5.0 TPI
Transmission: Manual
I had a 22, 34 and 44. Turned out the filament in the MAF was broken. I replaced it and that cleared 22 and the 44 but I still have 44.
Now the Idle sounds great in the driveway. Like a new car. When I drive it, the power is low and the engine intermittently shakes from about 16-2400 RPMs, Also the idle can get High when it is in gear. without touching the accelerator it hits 22 mph in first gear. It also hits about 2500 when I put the clutch down. Any idea what would trip the IAC? could the same cause the the shaking?
Old Apr 17, 2008 | 03:10 PM
slicef96's Avatar
Car: 1987 Trans Am
Engine: LB9 5.0 TPI
Re: Ugh ... 34 wont go away
Today it did the same shake on the way to work and I immediately hit the clutch and the engine died instantly. I am suspecting that the engine is stalling. And the bucking is the engine turning a stalled and “Jump Starting” it. Does this seem logical?
Pac J
May 17, 2020 10:44 AM
Mark_ZZ3
May 24, 2018 01:02 PM
BumpaD82
Feb 26, 2016 02:57 PM
383backinblack
Oct 14, 2015 08:50 PM
gta892000
Sep 16, 2015 12:40 AM
