Does the control module advance timing when...
Old Oct 1, 2001 | 07:49 PM
88TAJeff's Avatar
Car: 88 T/A
The tan/ black wire is disconnected, and the motor is revved up to 2500 rpm?
I get 6 deg. of advance sharply at 2500 rpm. Is this normal?
Thanks,
Jeff
88 Trans Am 305 Auto Red/Silver, MSD coil,wires, ported plenum, gutted airbox, TB bypass, comp cams 08-408-8, 206/212 @ 50 .480/.487 110 LSA everything else stock
Old Oct 1, 2001 | 10:56 PM
ViciousZ's Avatar
Car: 91 camaro
Engine: 383
I believe when the tan/black wire is disconnected the computer can't advance the timing at all, no matter what rpm you're at. So if you're getting 6* advance then that's good. That means your base timing is correct. If you want to watch it advance the timing then you need to use the timing light when the wire is plugged in.
91 Z28
Come see The Vicious...
Old Oct 1, 2001 | 11:04 PM
88TAJeff's Avatar
Car: 88 T/A
Oops. I didn't specify that it gives me an EXTRA 6 deg. of advance at 2500 rpm, and at idle it has 6 deg. So at 2500 rpm it's at 12 deg.
Old Oct 1, 2001 | 11:40 PM
Brent's Avatar
Yes its normal. The advance is built into the module.
Old Oct 1, 2001 | 11:42 PM
88TAJeff's Avatar
Car: 88 T/A
Thanks, Brent.
eightsixseven
Dec 16, 2024 01:50 PM
Ghettobird52
Jul 5, 2024 11:18 PM
justin57
Aug 20, 2015 07:05 PM
stalkier
Aug 13, 2015 12:59 PM
Thirim
Aug 9, 2015 06:19 PM
