carb to tpi
Old Apr 17, 2008 | 04:05 AM
xurusaibobx's Avatar
Car: 1991 Camaro RS B4C
Engine: 5.7 350 TPI
carb to tpi
okay gang i have a idea i not to sure if its smart or stupid but was wondering if you guys can help me out
i have a 88 safari van that i swapped in a 350 carb. (yes v8) right now it has a pre 87 heads but i wanted to swap in a TPI setup.
right now i have a 87 TPI MAF setup on the side am thinking about swapping in. not to sure if its worth the time or money to do something like this but i really wanted TPI.
i cant use the TPI base on the pre 87 heads right? or can it? with special washers for the center bolts? or do i need to find a corvette tpi base or buy the over priced aftermarked TPI base?
or should i just buy a 3rd gen lol
Old Apr 17, 2008 | 02:53 PM
87SSTPI's Avatar
Car: 1987 Monte Carlo SS
Engine: Vortec headed 350
Transmission: '89 WC T5
Re: carb to tpi
Many have simply just drilled the center bolt holes at a steeper or straighter angle(not exactly sure how to correctly term it) but the center holes on the intake 'should' match the angle as the other outer holes to make it work. I have never done this, but I know many people said they have and it worked just fine. This is only what I have read/heard so please take it as you may. HTH
gta90
Sep 15, 2015 04:00 PM
beachrodder
Aug 25, 2015 08:05 AM
theurge
Aug 21, 2015 12:46 PM
86IROC112
Aug 17, 2015 02:00 PM
Sanjay
Aug 12, 2015 03:41 PM
