compression ratio on a 305
Old Oct 2, 2001 | 01:17 AM
86IROCTHD's Avatar
Car: 88 Trans Am
Engine: lt1 intaked 355 makin 277 on 25 psi of fuel pressure and stock timing :)
Transmission: A4 stock... that moved a mobile dyno a foot shifting into 2nd :)
i already know that the 305 LB9 engines have 9.5:1. i just bought L98 vetter heads... i want more compression ratio.. the engine as bored .040 and i have to use the 350 head gasket what can i do to get more compression besides milling the heads or new pistions
305, TPI,compucam 2030 cam, air foil, 8.8 wires, accel super coil, dynomax headers, custom y-pipe, cut out, 80 series flowmaster, 2.73's and an open diff(3.42-3.73 on the way). and a stage 4 chip :0). hittin a sad 15.2 before the chip.
Old Oct 2, 2001 | 01:31 AM
tpi_roc's Avatar
Nothing
Those are the only two ways
unless you run super rich and get excessive carbon buildup
Old Oct 2, 2001 | 01:33 AM
86IROCTHD's Avatar
Car: 88 Trans Am
lol by running the 350 gaskets will it up ,u compression ratio. cause i have the 305 gaskets on there now dont know how thick they are.....
beastin91rs
Oct 9, 2015 07:38 AM
gixxer92
Sep 1, 2015 04:32 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
happyhapka
Aug 15, 2015 04:42 PM
