Tach reading is off!!!!PLEASE HELP!!!!!
Old Oct 1, 2001 | 08:51 PM
AaronIROCZ's Avatar
Moderator/TGO Supporter
I have posted this in the electronics page with no response.
Ok I have a 87 GTA with the digital dash, 350 TPI that had an engine fire. Ok I used a engine harness from a 87 IROC and the headlight harness from a 86 T/A. The problem I have is that when the tach displayes 6000 RPMS it is at 3000 RPMS. I know this because I hooked up a digital timing light that had a tach display on it. The distributor is out of a 87 Monte Carlo SS. Anyideas to what could be causing this? PLEASE HELP!!!!!
89 Iroc 350 TPI,
Forged pistions
Comp roller Cam .510 lift 230dur
Flowmaster exhaust
Dart Iron Eagle heads 200cc runners 64cc chambers
MINI RAM SOON!!!!!
stock TPI for now 24# inj
87 Trans Am GTA 350 TPI
had engine fire
SHE NOW RUNS!!!! GREAT!!
Flowmaster exhaust
LT1 Injectors
Old Oct 2, 2001 | 12:50 AM
86IROCTHD's Avatar
Car: 88 Trans Am
Engine: lt1 intaked 355 makin 277 on 25 psi of fuel pressure and stock timing :)
Transmission: A4 stock... that moved a mobile dyno a foot shifting into 2nd :)
no but i have had the same problem and i just put in an aftermarket tach.
305, TPI,compucam 2030 cam, air foil, 8.8 wires, accel super coil, dynomax headers, custom y-pipe, cut out, 80 series flowmaster, 2.73's and an open diff(3.42-3.73 on the way). and a stage 4 chip :0). hittin a sad 15.2 before the chip.
Old Oct 2, 2001 | 09:09 PM
AaronIROCZ's Avatar
That would work but I would like to try to keep the interior looking orginal, But it is looking like I might have to do that, because nobody has any idea what is wrong.
89 Iroc 350 TPI,
Forged pistions
Flowmaster exhaust
MINI RAM SOON!!!!!
had engine fire
Flowmaster exhaust
LT1 Injectors
Hotrodboba400
Dec 10, 2019 07:07 PM
eustodp
Sep 20, 2015 05:09 PM
TrevinE
Sep 14, 2015 03:20 PM
andy74
Sep 3, 2015 08:41 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
