Blown fuel line, GAS+ EXHUAST=BIG FIRE BALL.
Car: 87Z
Engine: ?
Transmission: A4
I had a little accident yesterday, I had one of the rubber fuel lines under the hood pop on me. Here is a sipmle equation for you GAS + EXHUAST MANIFOLD=BIG FIRE. The fire didnt do alot of damage just melted a little plastic, but the two hi pressure rubber fuel lines are toast. Has any one had to replace theese if so were did you get them, what is there part #, and how much?
87 Z28 305 TPI, Auto, LT-1 cam (@.50 418/430, 194/199, LSA 111), roller timing set, 2.73, Gutted air boxes, K & N fillters, Dyno Max 3" cat back, 8.8 mm spirals, air foil, BFG Drag radials,170* Stat and TB bypass.
Old Best 15.414 @ 87.47.
new best 15.006 @ 89.55.
w/ drag radails 14.6 @ 93
“Fallen But Not Forgotten”
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
you can get them from anywhere.autozone pepboys,"gm dealerships".providing they are made from a reliable manufacturer and are the high pressure hoses you need.
87 trans am,gm crate 350(4 bolt mains 10to1),L98 aluminum heads,LT4 hot cam,slp runners,slp 1 5/8 headers,3in.y-pipe,edelbrock base,hi flo cat,air foil,afpr,as&m ported plenum,gutted airbox,t-5 tranny w/centerforce clutch and a 3.27 9bolt(11.9in. brakes),ed wright's fastchip,relocated iat sensor,160 fan switch&t-stat,tb bypass,accel supercoil,cap& rotor,slp 3in. catbcak,a/c delete.
SHE IS GONE BUT I KNOW THE GUY WILL GIVE HER A GOOD HOME.
best e/t:
3653lbs./full tank+ driver.
14.10@96.53mph 2.01 60'
best e/t:
The dealerships will also have nothing for you. GM discontinued the high pressure feed line but about 2 months ago I was still able to get the return line. You will have to have one specially made for you or find one at a junkyard, TPI,TBI they both work. My feed line was from a 88 Camaro with TBI, it worked just fine.
89 Iroc 350 TPI,
Forged pistions
Comp roller Cam .510 lift 230dur
Flowmaster exhaust
Dart Iron Eagle heads 200cc runners 64cc chambers
MINI RAM SOON!!!!!
stock TPI for now 24# inj
87 Trans Am GTA 350 TPI
had engine fire
SHE NOW RUNS!!!! GREAT!!
Flowmaster exhaust
LT1 Injectors
89 Iroc 350 TPI,
Forged pistions
Flowmaster exhaust
MINI RAM SOON!!!!!
had engine fire
Flowmaster exhaust
LT1 Injectors
I will be replacing mine with SS braided, the, fromt the body to the rails so, If they guys still has them I will sell them to you for $5 plus shipping.
1987 Black 305 TPI 5spd IROC, seems to be fully loaded, but can't find RPO codes.
AIM: IROC 5spd
http://www.geocities.com/chevy5spdiroc/87Roc.htm
AIM: IROC 5spd
Car: 87Z
Engine: ?
Transmission: A4
<font face="Verdana, Arial" size="2">Originally posted by AaronIROCZ:
</font>
</font>
<font face="Verdana, Arial" size="2">Originally posted by camaro6spd:
</font>
</font>
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
CAP (consumer auto parts) sells high pressure fuel line (good for like 300lbs) and clamps..
A lot of the import shops around mine use it for their v-tec setups.
You can also use ntp fittings and good steel
line.
-- Joe
line.
-- Joe
theshackle
Mar 5, 2017 06:37 PM
AkDrifted
Aug 17, 2015 07:45 PM
