How to tell injectors apart
Old Oct 9, 2001 | 11:28 PM
Ehelmsin's Avatar
Is there a way to tell lbs/hr by looking at an injector, my buddy bought a TPI and we don't know if it was off a 350 (22 lbs) or a 305 (19 lbs) Also could we pick up some injectors off an LT1, 24 lbs right, and throw them on without any major problems?
Ps. Please correct me if I got any thing worng here, those flow rates are correct?
Old Oct 10, 2001 | 09:05 AM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
The injectors will have a part number on them somewhere, most likely in really small embossed type near the connector.
Once you have the part numbers try searching around on the board for it and see what you find. If you can't find it that way, post it and somebody will prolly know.
Ed Maher - Moderator @ The TPI & Carb Boards
92 Z28 Convertible - Quasar blue / Tan top
305 TPI A4 2.73 - 14.8 @ 93.1
Stock except ported plenum and dual cats
-=ICON Motorsports=-
- Definitely prototypes, high powered mutants of some kind. Too weird to live, too cool to die
Old Oct 10, 2001 | 10:56 AM
Desert86Roc's Avatar
If the injectors have not been painted, most are color coded. Black topped ones are 19#, grey are 22# (or vice versa.. I have to look).
Old Oct 10, 2001 | 04:23 PM
Ed Maher's Avatar
Car: 04 GTO
I don't know if that is all true though mike. For example, you are at least backwards in saying 22s are gray and the 19s are black, cuz i have black 22s from an 88 MAF car in my LB9 right now, and the stock injectors were gray 19s.
If he's holding the injectors it's just as easy to look at teh PN as it is to go by color...
Old Oct 10, 2001 | 06:18 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
I use to think the same thing as Desert, but I am now thinking as Ed. I think the color probably has more to do with the manufacturer.
PS: My injectors on my L98 have purple tops.
Old Oct 10, 2001 | 07:23 PM
Mark_ZZ3's Avatar
Car: 1989 Camaro-1LE
Engine: TPI(s)
Transmission: 5 speed (MM5, MK6)
Axle/Gears: 3.45, 3.73
I have a list you can look at:
http://www.epsb.net/~mstrembi/injectors.htm
Scroll to the bottom the a GM TPI injector list. I only have the ones from 85-89 or so.
Mark.
92-Formula
Dec 12, 2015 10:34 PM
rubyred88
Sep 17, 2015 02:19 PM
thejimsterz28
Sep 15, 2015 04:37 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
