low rpm problem w/ v8 tpi
Old Oct 11, 2001 | 09:48 PM
91fbirdgta's Avatar
Car: 91 Firebird GTA
hey guys, i got a problem. i just got a 91 firebird gta w/ a 5.0 tpi in it. the problem is that the car's rpm goes below 1000, then comes up a bit, then drops down, then back up, and then back down again-u get the point!
the car drives great, but when i come to a red light or stop, the car goes into the low idle and it sometimes stalls- does anyone know what the f is wrong w/ it? i was thinking that the throttle had to be adjusted to up the rpm, right? if so, how do u do that??? thanks guys!!!!
Old Oct 11, 2001 | 09:53 PM
Lov2xlr8's Avatar
Your idle surge is common amoung third gens, it sounds like your throttle position sensor. I would get a new one and have it set properly to .5 volts and idle and 4.0 at full, I could be wrong, about the numbers, but I will bet thats its your TPS.
Old Oct 11, 2001 | 09:55 PM
Lov2xlr8's Avatar
another thing if you have a constant low idle, that oculd mean somone screwed with the stock idle screw, look at the back of the idle stop screw, there should be a metal cover, if its not outed somone changed the idle, you can use a T 10 torx bit to raise it. but I think its your TPS because your idle surges , if it was just low I would say raise your idle.
Old Oct 11, 2001 | 09:57 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I'm thinking your injectors.
Old Oct 11, 2001 | 10:05 PM
91fbirdgta's Avatar
thanks Lov2xlr8, sounds good, and once again, i'm open to opinions!!!
thanks!
Pac J
May 17, 2020 10:44 AM
FormulasOnly
Jul 23, 2018 08:47 AM
cheesehomer
Dec 31, 2015 08:48 AM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
