305 heads
Old Oct 9, 2001 | 10:03 AM
camaro6spd's Avatar
305 heads
what are good for 305, the torqer, ported LB9 or corvette L98?
1987 Black 305 TPI 5spd IROC, seems to be fully loaded, but can't find RPO codes.
AIM: IROC 5spd
http://www.geocities.com/chevy5spdiroc/87Roc.htm
Old Oct 11, 2001 | 11:16 PM
Guest
Guest
Posts: n/a
Depends on what you want to spend as well. I hear the torquers work well, and they are new too unless you pick up a used set, but new they are pretty inexpensive.
Porting the stock set works ok, but then you spend another few hundred on springs, valve job, whatever else... like surfacing. Good idea if youre on a budget.
The L98 aluminums are nice, but I wouldnt buy a new set, just too expensive that way. You can make them work good on a 350, and a 305 its even better. Take a look at what Willie has accomplished with them, very impressive.
Old Oct 12, 2001 | 10:04 AM
camaro6spd's Avatar
Willie.....you there?
Jake_92RS
Jan 28, 2020 10:37 PM
gta90
Sep 15, 2015 04:00 PM
theurge
Aug 21, 2015 12:46 PM
