Info please
Old Apr 26, 2008 | 09:53 AM
a911medic's Avatar
Info please
I'm not new to camaro, i'ved owned 6 so far in life, but TPI is new to me. I just purchased some 1986 L98 AL heads to go on a 350. I have a TPI setup from an 88 IROC.
Are these compatible? Will I be able to bolt this TPI to these heads?
I'm sure this question is on here somewhere but I cannot find the info I need here or on the web.
Old Apr 26, 2008 | 10:14 AM
Jay's Avatar
Jay
Car: 88 IROC
Engine: 5.7 RamJet
Axle/Gears: Dana44 4.10
Re: Info please
You'll have to modify the intake, the 2 center bolts on each side that hold it to the engine will need to be redrilled for the proper angle to match the heads.
Old Apr 26, 2008 | 10:40 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
Re: Info please
if they are aluminuim than they were made for the corvette that had a external egr system
you will have to elminate your egr
Fanatic1074
Oct 3, 2022 05:57 AM
3rdgenparts
May 21, 2016 11:50 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
bjpotter
Oct 4, 2015 07:48 PM
Linson
Oct 1, 2015 09:50 PM
