When converting from TBI to TPI????????
If I don't change the cam when i do the convertion is it really going to hurt my performance? Also I have a couple of high performacne vette heads off my Dad's L82 vette. They are 1.94/1.6 valves and i was thinking of porting and polishing them instead of getting the AFR's. Will they bolt up to my 89 block? and will my 86 TPI work with the heads?
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
I believe so, you should be able to use your dads heads with an 86 intake. The heads should bolt up as well.
The cam you have in your car is the same as the stock cam for the 5.0 TPI Automatic, so your performance will be ok. If you simply put in an SLP Cam then you could really benefit from your mods.
Word of wisdom from experience IF you have an 86 PROM, ditch it and go with something newer. I programmed my own and used the ARAP Bin from an 89 Vette.
John
G O D BLESS AMERICA
87 Formula Yellow/Black
5.1 TPI Automatic
Baer 12" brakes 4 wheels, KYB AGX Adjustable Shocks & struts, Custom Leather interior, WAAAY TOO MANY MODS TO LIST
87 Formula TPI (5 Speed) Yellow/Gray STOCK
1967 Buick Riviera 430hp Turns high 14's (Not bad for 4300 lbs)
83 Camaro
83 T/A
http://www.3rdgenformula.com
John
G O D BLESS AMERICA
5.1 TPI Automatic
83 Camaro
83 T/A
the block itself is the same. the only difference is the angle of the center intake to head bolts and the bolt location on the valve covers. the head to block bolts are the same on all small blocks.
evilstuie
Jan 9, 2020 08:29 PM
Sanjay
Aug 12, 2015 03:41 PM
