Accel Manifold Clean-up
Old Oct 15, 2001 | 11:51 AM
TPI Guy's Avatar
Car: 1968 Camaro
Engine: 406
Transmission: Tremec TKO
I just purchased an Accel TPI Manifold at the Detroit Auto Swap Meet yesterday. I got it home, and looked inside, and there seems to be excess casting material in the runner. This is understandable due to the need to suspend the cores during casting. My question is...
#1. Is it going to be worth my time to clean up the ports to achieve a near perfect geometric shape and uniform wall texture with a die grinder.
#2. Assuming this doesn't inhibit airflow, what kind of surface finish am I looking to achieve? Because fuel doesn't atomize in the manifold, I would expect a near mirror finish would be best, but I'm open to suggestions. If not, what is the last grit that should be used?
#3. Anybody have before and after flow numbers?
355 c.i.
Dart 180 Heads
Lunati 224/224 cam
Harland Sharp 1.5 rockers
Performer RPM Manifold
Holley 600 cfm double pumper
Hooker Super Competition Headers
Flowmaster Exhaust
Competition Engineering Sub-frame connectors
Super T-10
GM posi 3.42 rear
Hurst Roll Control
13.9@102
Old Oct 15, 2001 | 01:03 PM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
I flowed a stock Accel base versus a $250 ported base, and the difference was a whopping 2 cfm for the ported base.
At least the ported base looked better on the inside!
The trick is to increase the cross-sectional area as large as possible. Open it up as wide as possible.
Fanatic1074
Oct 3, 2022 05:57 AM
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
Chas91Z28
Oct 22, 2015 10:12 AM
efiguy
Sep 27, 2015 01:30 PM
