Idle question...
Idle question...
I needed a new fu;le pump, so I got one and my idle is still at about 550 to 600 rpm, how do I get it to about 700-750?
- Red '91 Z-28 350
- 700-R4 Trans
- T-tops
- no major power
gaining mods, K&N
Filter, Flowmaster
exhaust -series 80-,
exhaust cut-outs - Best E.T.= 14.7@93.8mph,
- HardlinePerformance
[URL=http://www.hardlineperformance.8m.com/propics/camaro2.gif[/URL]
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
Tell your computer to idle at the higher speed. To do this, you need to burn your own chip. See Traxion's article at the top of the DIY_PROM board on how to do this.
Greg Westphal
'87 IROC 355TPI/A4
Greg Westphal
'87 IROC 355TPI/A4
Car: 1968 Camaro
Engine: 406
Transmission: Tremec TKO
My first question is why? But here goes. On the back of the throttle body there is a screw that controls the postion of the throttle blades. Sometimes there is a cap on top of the recess in the throttle body where the screw is contained. Try tightening it once it is warmed up.
And then the IAC will just bring the idle back down to 550RPM and your TPS may be out of whack.
Greg is right, learn to burn your own PROMs or have someone do it for you. Having tried both ways, the PROM way is the only way to go.
1990 IROC 350
Mods: Too busy trying to make it run right to mod it.
Airfoil, Dynomax cat-back, MSD coil, 180 t-stat, Bald Eagle tires,
Hypertech fan switch, Accel 23# injectors, Holley module, ported plenum,
Ported Daytona Yellow stock base, Moroso valve covers, other stuff,
Streetdampr, Ruger P95DC, hot wife, new oil filter, !cats, !TBC, !AIR.
18.0 @ 85MPH since I'm one big-a$$ MF
"It's better to have and not need than to need and not have."
1990 IROC 350
