Rich ? Lean ? What gives ????
Old Oct 17, 2001 | 07:42 PM
TPIJeep's Avatar
Engine: 7.4 L of Small Block Fun...
I have a Speed Density TPI unit on a SB 415 with cast heads and 10.5:1 compression and my headers are glowing even with moderate driving or just reving it up in the driveway. I am running 24 lb injectors, I have set my min idle and TPS to .54v. I had a custom PROM burned by Jimsperformance.com My base timing is set at 2 degrees AFTER TDC with the set timing plug undone. I just replaced the O2 sensor just incase it was bad and it did not help.
Before you say my timing is to retarded I had this same problem when the timing was set at 12 Before TDC. I backed the timing down to help control the clatter.
Where should I go from here? Who makes and Where can I get a good scanner for the computer. I am at wits end please give me a hand with this.
Thanks..
Old Oct 18, 2001 | 08:00 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Have you checked your spark plugs, or at least A spark plug and see if it is lean or rich??
John
Old Oct 18, 2001 | 08:11 AM
TPIJeep's Avatar
I pulled a few plugs and I would say they look about perfect.
Old Oct 18, 2001 | 09:15 AM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
I think the answer is pretty obvious. That custom chip is obviously COMPLETELY wrong. If i were you i wouldn't turn that engine over a single turn until i replaced that chip.
Even though 24lb injectors could be choking your power depending on your heads/cam, they would be able to 'drive' in the normal sense of the word just fine.
My suggestion is to learn how to burn your own PROMs. I bet you'll laugh when you see what you paid for from jimsperformace...
Old Oct 18, 2001 | 04:40 PM
TPIJeep's Avatar
Ed,
Since I know absolutly nothing about custom programming what parameter would you think is causing this?
If I get the equipment to burn them myself will I be able to read the bin file off my prom and make changes to it, or will I have to start from scratch.
The process seems pretty easy but I would like some idea where to start and what to look for.
Thanks..
F-body-fan
Jan 12, 2023 01:49 PM
Mark_ZZ3
May 24, 2018 01:02 PM
antman89iroc
36
Jan 31, 2016 08:42 AM
Luigytico09
Oct 1, 2015 08:46 AM
Jk_Under
Sep 8, 2015 08:13 AM
