88 stock l98 injectors?
Old May 1, 2008 | 09:42 AM
350fomula's Avatar
Car: 1988 Formula
Engine: 350 L98
Transmission: 700R4 w/corvette stall and servo
Axle/Gears: 1998 Transam 2.73 posi.
hey guys....i really need some help here. i am going to change out my injectors.my first injector change. i have read and heard anywhere from 19# to 24# injectors,for a stock 350. and i just got off the phone with summit. one guy said "summit's ford injectors" (#sum-240024) would be perfect, i called back to ask about a gasket set, talked to a different guy,he said the ford injectors where a different size and they may fit loose in the fuel rail. he tried to sell me some accel's,but from what i have read,they may not be the best ones. i will be installing hooker 2055's later.
has anyone used these injestors?again they are (#sum-240024)
if these will not work, does anyone know of a good replacment set?
do i need 24# injectors?
thank guys.
i love this site!!!!!!
Old May 1, 2008 | 10:07 AM
battman's Avatar
Car: 87 GTA, 88 GTA, 92 TA, 72 RS SS
Engine: 350, 350, 305, 396
Transmission: T56, 700r4, 700r4, T56
Axle/Gears: 3.42, 3.23, 3.23, 3.73
Re: 88 stock l98 injectors?
The ford injectors will work fine, I have run them, No fitment issues. I would look on ebay:
http://cgi.ebay.com/ebaymotors/Musta...QQcmdZViewItem
PS: if your car came stock with a L98, it uses 22# injectors
Old May 1, 2008 | 10:51 AM
thunder85's Avatar
Car: 1988 firebird trans am GTA
Engine: 5.7L w/hsr
Axle/Gears: posi 3.23
call jon at fuel injector connection (FIC). he hooked me up with bosch type III injectors that seriously improved my engine performance and efficiency. you will love them
Old May 1, 2008 | 09:02 PM
irocuroc's Avatar
Car: 89 iroc
Engine: l98
Transmission: tremec
i got mine also for my two cars.. i have sent a bunch of friends to him... get the design III and you will be happy
www.fuelinjectorconnection.com
the link for the e bay guy.. those sets are not flow balanced.. with our batch fire you really need matched injectors.. i have found out the hard way..
Old May 1, 2008 | 10:09 PM
350fomula's Avatar
Car: 1988 Formula
Engine: 350 L98
do you have to change the your plug(connectors) if you use bosch type III injectors? and if i go with 24# injectors will it make her run rich? i live in a smog county.
once again.....first time injector change. i just want to get the right ones.
thanks again
Old May 1, 2008 | 11:04 PM
irocuroc's Avatar
Car: 89 iroc
Engine: l98
thanks again
the bosch III jon has is the same plug as ours.. they just drop in.. easy install. a little time consuming... go with the 22's. bigger injectors do not give you more power. you will have too do a chip reprogram to run 24's properly.
Old May 2, 2008 | 10:26 AM
350fomula's Avatar
Car: 1988 Formula
Engine: 350 L98
thanks guys.....i just got off the phone with jon @F.I.C. and man he really knows his stuff. super nice guy. saids he has been doing it for 30 years. he even gave me his cell and said "call anytime day or night,my phone is always on". ARE YOU KIDDIN' ME !!!!!!! you can never find that kind for service nowadays. i gettin' the type III's 22# injectors. i am sure they will work great. anyway thanks again guys.
i love this site !!!!!!
Azrael91966669
25
Jun 20, 2017 04:04 AM
gta90
Sep 15, 2015 04:00 PM
TheExaminer
Aug 19, 2015 10:07 PM
matthew911
Aug 12, 2015 09:38 AM
jpearcy1
Wheels and Tires
Aug 9, 2015 10:20 AM
