modding the intake
Old Oct 19, 2001 | 03:43 AM
TA88GTA's Avatar
modding the intake
I'm swapping to perimiter bolt heads and just wanted any helpful hint or tricks to drilling the intake to fit the new four center bolt angles
Old Oct 19, 2001 | 03:44 AM
Tas's Avatar
Tas
just grind them into an oval shape. No drilling required.
-Tas
'89 Formula WS.6
Got Beach?
Old Oct 19, 2001 | 04:37 AM
TA88GTA's Avatar
wit a dremel??
Old Oct 19, 2001 | 11:57 AM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
I haven't actually done this mod, so i'd verify it first, but just by looking at it, it seems to me that Tas is right. You oly need to grind out the bottom of the bolt holes so that the bolts are free to go perpendicular to the face of the intake, instead of at a 72' or whatever angle. The bolt hole is definitely in the same spot, it's just the angle the bolt goes on thats different.
Ed Maher - Moderator @ The TPI & Carb Boards
92 Z28 Convertible - Quasar blue / Tan top
305 TPI A4 2.73 - 14.74 @ 93.25
Stock except ported plenum and dual cats
-=ICON Motorsports=-
- Definitely prototypes, high powered mutants of some kind. Too weird to live, too cool to die
Old Oct 19, 2001 | 12:38 PM
afgun's Avatar
Car: Non F-body :(
Engine: Pontiac 301
Transmission: TH350
I modded a later-style intake to fit standard angle bolt heads with just a rat-tail file. Be warned, this method will take some time and elbow grease, but it was quite straight-forward to do.
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
toronto formula
Sep 10, 2015 07:31 AM
L0tuS
Sep 4, 2015 11:16 PM
