Is a 87-88 305 TPI computer compatible w/ a 89 305 TPI engine harness?
Old Oct 19, 2001 | 11:48 AM
vortech305's Avatar
Just curious, cause im sort of in a bind as of now
Old Oct 19, 2001 | 11:55 AM
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
I'm gonna Yes since the sensors are all the same (except for the deletion of the cold-start injector in '89). And, since you can run '89 code in an '87 or '88 F-body, then the sensors must report back to the same pins (or wherever) in the computer.
Greg Westphal
'87 IROC 355TPI/A4
Old Oct 19, 2001 | 12:44 PM
Guido's Avatar
Car: 2000 Trans Am
The ECM's are the same.
I think the PROM is different. 89 uses ARAP right?
-86 IROC
-=ICON Motorsports=-
Old Oct 19, 2001 | 12:50 PM
Engine: 385 HSR
Right, well, not from the factory, but it's what most of us MAF guys are using. Any PROM from any '86-89 TPI F-body will work in any '86-89 TPI F-body, although it helps if they're for the right combination (engine, tranny etc.) or programmed for the particular combination.
Greg Westphal
'87 IROC 355TPI/A4
Old Oct 19, 2001 | 01:41 PM
afgun's Avatar
Car: Non F-body :(
Engine: Pontiac 301
Transmission: TH350
If you're going to use the '89 harness, you need to use an '89 PROM because there's no cold-start injector.
Old Oct 19, 2001 | 04:09 PM
vortech305's Avatar
well i think i was screwed cause if the harness was an 89' there wouldnt be a harness for the cold start injector and there is, so the harness must be an 87-88' besides all of the relays that i bought from stores were rectangular instead of the ovals which where given in 89'.
Orr89RocZ
Apr 25, 2016 08:28 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
theurge
Aug 21, 2015 12:46 PM
jharrison5
Aug 19, 2015 05:53 PM
Sanjay
Aug 12, 2015 03:41 PM
