Port Matching Questions for TPI parts.
Old Oct 19, 2001 | 10:34 PM
Dan87IROC-Z's Avatar
I have the LPE SuperRam base, not ported or anything, just straight out of the box. I would like to get a set of the SLP runners from Summit. My question is, will I have to port match (or something) them to the plenum and/or to the base, or can I just bolt them on and go? Thanks!
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End with 2.77:1 Gears.
Current Mods: LT4 HOT Cam, Comp Cams 1.52:1 Roller Rocker Arms, Accel High Flow TPI Baseplate, Edelbrock TES 1 5/8" Headers, Catco 3" High-Flow Catalytic Converter, Hooker 3" Aerochamber Cat-Back System, Transgo Shift Kit, Performance Resource Chip, Accel Ignition, K&N Filters, Jet TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET: 14.32 @ 97.7mph
(corrected for elevation)
Old Oct 20, 2001 | 08:19 AM
HiTech5's Avatar
Car: 1986 Pontiac TA
Engine: 383
Axle/Gears: 3.70
The more important match is the plenum to runner. I believe that you will find the SuperRam base to be slightly larger than the SLP runners. This will not present a problem. But for ultimate performance, port match both.
www.geocities.com/dzperf
D&Z Performance
"Putting Power to the Pavement"
Old Oct 20, 2001 | 11:45 AM
RCR's Avatar
RCR
Car: '84 Fiero ('01 GA interior)
Engine: '96 4.0 Aurora
Transmission: '96 4T80E
There are pics on my site of what I did.
Bob '89 Ram Air Formula 350
And until that time when death won't wait, let each man rage against his fate. (O'neill)
My car's homepage
Rider's Ride
Vintageracer
Jan 10, 2020 05:33 PM
Caspar
Jun 19, 2016 11:19 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
Sanjay
Aug 12, 2015 03:41 PM
