Starting Problems
Old Oct 20, 2001 | 04:14 PM
tpi4me's Avatar
Starting Problems
I just put on a used set of injectors and just my luck one leaks, will this leaky injector keep the car from starting at all? If not what do you guys think it is? It will just crank and crank and no start...
Any help would be appreciated
-Gabe
Old Oct 20, 2001 | 04:38 PM
ede's Avatar
ede
what have you checked? anything or just ask on the message boards? do you have fire? compression? air/fuel mix? if so it should fire, long as you've not changed anything. why did you change injectors? did it work before you made the change?
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Oct 20, 2001 | 05:05 PM
tpi4me's Avatar
I have already checked to see if the plugs fire and they do, it is not flooded, compression is fine, the only thing that i changed was the injectors, and i did that because the last set was too big.
-Gabe
Old Oct 20, 2001 | 05:07 PM
tpi4me's Avatar
sorry....yes it did run before the injector swap, just not very well due to the oversize injectors
Old Oct 20, 2001 | 10:57 PM
airdeano's Avatar
gabe,
do you know what these injectors are?
if they are more than 14ohms resistance each
possible the injectors are more for DFI systems.
the stock computers can only take 14-17ohms
saturations injectors. there are different
type injectors.
ive ran into the same injector problems.
installe 26# msd 2ohm injectors and the car would
not start. reinstalled the 24# svo 15ohm and
the car started. replace the injectors with
accel 26# 14ohm and we started again.
the 2ohm is too much for the computer to drive.
thats 1ohm to open and one to hold open.
from experience.
do you really know what these injectors are?
Old Oct 21, 2001 | 02:06 PM
tpi4me's Avatar
airdeano,
the injectors are out of a tpi 'vette (L98), except he had the cold start injector, would that make a difference since i dont have it?
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
92camaroJoe
Aug 13, 2015 06:07 AM
mustangman65_79
Aug 8, 2015 12:07 PM
