Losing fuel pressure immediately after prime...
Old May 4, 2008 | 07:52 PM
WhiteIrocZ's Avatar
Car: 87 Iroc Z
Since I have bought my car, it has been hard to start when it is hot. I just recently put a fuel pressure gauge on the rail and as soon as the fuel pump primes, it starts on its way to zero. It takes maybe 3 seconds to go from 45 to 0. I have new injectors and a new AFPR that is going on this week, also deleting the cold start injector. What else could it be other than that if those parts don't fix it? Could there be something up with the fuel pump?
Old May 4, 2008 | 08:34 PM
midwest's Avatar
Re: Losing fuel pressure immediately after prime...
Most likely your diaphram in the fuel pressure regulator is ripped and allowing fuel to leak into the intake, flooding out the motor. Change the regulator
other wise it could be a leaking injector
To check the regulator pull the vacum line off of it, it any fuel comes out the reg is junk.
Old May 5, 2008 | 06:58 PM
WhiteIrocZ's Avatar
Car: 87 Iroc Z
I dont think the diaphram is torn because there is no fuel that comes out when the car is running. I hope not anyways because my afpr from tpi parts didnt include a diaphram. Where can I get just a diaphram? I just got my injector rebuild kit for some LT1 injectors I had. I also just got the new prom in so they will probably be in within this week, we'll see. I guess if that dont fix it, the fuel pump is next. What do you guys think?
Old May 7, 2008 | 03:45 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Autozone sells the replacement diaphragm and spring for $40, I just replaced mine. If you plan on getting an AFPR, note that none of them except the Holley come with a new diaphragm.
Old May 11, 2008 | 11:42 AM
83Firebird420's Avatar
Car: 87 GTA 120,000k, 90 CRX Si
Engine: 5.7 TPI, 1.6L 16 valve SOHC
Transmission: 700r4, 5spd std
yeah they really need to state that in the description.
Old May 11, 2008 | 12:00 PM
Vader's Avatar
If you suspect the FRP, simply pinch the fuel return line and retest pressure.
Old May 12, 2008 | 09:35 PM
t/agta's Avatar
Car: 87' Trans Am GTA, 88' Trans Am GTA
which one is the return line?
Old May 14, 2008 | 11:42 AM
WhiteIrocZ's Avatar
Car: 87 Iroc Z
I finished replacing the injectors and the fuel pressure regulator and deleted the cold start injector. Diaphram looked great. I guess its time for a pump, right? If I buy a Walbro 255, does the diaphram for it come with it or is that separate? What else could it be other than the return diaphram in the tank?
Old May 14, 2008 | 11:51 AM
Quick_Trans_Am's Avatar
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
The smaller of the two.
92camaroJoe
Jul 29, 2023 07:57 PM
specialized
Jun 18, 2022 09:26 AM
R3500
Aug 17, 2015 12:16 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
