Serpentine conversion???
Old Oct 24, 2001 | 08:56 AM
Hg's Avatar
Hg
Car: '87 Z
Engine: 355 in the works
What exacty is sepentine? From what I've read it basically replaces all your belts with a metal chain so nothing slips, is this right? How much does it run, and how hard is it to install? I've read that it can give you a possible 20hp increase, how can different belts/chains add hp?
Old Oct 24, 2001 | 10:34 AM
TPI Guy's Avatar
Car: 1968 Camaro
Engine: 406
Transmission: Tremec TKO
Buddy, you have to do a little more research before you post a question like this.
Serpentine, in the context of this message board, refers to the belt set-up on 88-92 camaro's and firebirds. The accessories are mounted to the engine block with aluminum brackets, and a single belt is employed to move all the pulleys. This belt snakes through the pulleys hence the serpent designation. Tension is given via a tensioner pulley also mounted to the brackets.
Belts are not made of metal. They are composed of the conventional belt material.
If you want to buy a set-up new, you are crazy. They can be found at Jim Pace, and www.sdpc2000.com or if you have thousands of dollars to throw away, March. Your local junk yard is your best bet. I picked up a set-up for 20 bucks. Just don't try to pocket anything while you are there or the Junk yard guy will flip and you will never be allowed in the junk-yard again.
OK, now this system will not add horsepower. There are very few things that add horsepower. What it will do is not take as much horsepower away from the engine. 20 hp is doubtful ...
Old Oct 24, 2001 | 10:35 AM
MAXGTA2002's Avatar
the serpentine is a set up that replaces all your belts and alines your pulleys for one belt instead of 4 or 5 belts which will lesson the drag on the engine. if your interested I have a set of brakets w power stering pump and puleys.
[This message has been edited by MAXGTA2002 (edited October 24, 2001).]
Old Oct 24, 2001 | 05:52 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Look at the before and after pics, and you will see the difference between V-belts and Serpentine belts.
Serp Belt Swap
If you live in Southeastern US, check us out!
South East Thirdgen
1987 Trans Am 305
14.88 @ 92.81
Old Oct 24, 2001 | 08:14 PM
ws6transam's Avatar
Car: 1984 Trans Am WS6
Engine: Minirammed 385, 396 RWHP
Axle/Gears: 3.73 Moser 12-bolt
<font face="Verdana, Arial" size="2">Originally posted by GMTech:
Serp Belt Swap
</font>
I want to know if your serpentine belts are any quieter or help the engine rev any easier. I have the conversion sitting here in a box just waiting for the new motor. Geez, this is taking too long! It's been almost 14 months!
Daniel Burk
View my third-gen hobbyist performance page!
View my reader's ride!
'84 Trans Am WS6/L69
KB SFC, Moser axles, Torsen Diff., Spohn Adj. torque arm,
Ported 305 heads w/1.94"intake valves, Comp Cams XE262H, Griffen alum. radiator,
Turbine Technologies 2500 stall converter, underdrive pulleys, Crane Hi-6 & more.
1.05g skidpad verified.
Best of 14.039 at 100.82 MPH in Stanton, MI
New!Full 1LE brake upgrade! Details at website above.
Old Oct 24, 2001 | 08:40 PM
Tas's Avatar
Tas
be careful. I think serpentine cars have reverse rotation waterpumps. just changing the belt seup could have your pump pumping the wrong way.
-Tas
'89 Formula WS.6
Old Oct 24, 2001 | 10:20 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Yes, the pump does rotate backwards, that was mentioned in the article.
I did notice that the serp belt was quieter, and it just seemed smoother. I didn't say it made the car faster, it just seemed a little smoother, watching it idle. The belts don't squeal at higher RPM or when I splash through a puddle either.
Also, repairs are so much easier. Instead of losening twelve brackets and getting all the damn belts in a knot, all it takes is one 1/2" drive pull handle and the belts off, then each accessory is only held on by two or three easy to access bolts, unlike the cobbled together mess GM origianally had.
South East Thirdgen
1987 Trans Am 305
14.88 @ 92.81
Linson
Oct 24, 2025 02:00 PM
jrdturbo
Mar 31, 2016 02:58 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
loud91rs
Oct 5, 2015 10:05 PM
mfp189
Sep 27, 2015 09:25 AM
