Valve covers for TPI, AFR heads(center bolt) and full 1.6 rr
Car: 1987 Iroc
Engine: 357 Single plane and a Ysi vortech
Axle/Gears: 3.50 9"
I am getting the run around with valve covers also. What valvecovers can I run with a full 1.6 roler rocker and still clear the TPI on my AFR heads? Thank You
Chris
Chris
I'm using AFR 195, Crane 1.6 full-rollers, Edelbrock big runners and base, and use Mr. Gasket valve covers. My valve has .504" lift on the exhaust if that matters. I still use the AC too. It's easier to remove them first to remove the runner bolts, but once on, no sweat.
Car: 1987 Iroc
Axle/Gears: 3.50 9"
Thanks. Do you have a part number or anything? That sounds like the same cam I want to use. Are they black, chrome or what? Could you e mail me @ NufNuffZ28@yahoo.com I want to know what you think of your setup as mine is very similar.
Chris
Chris
NBrehm
Aug 25, 2015 11:49 PM
