Need Help!!
Old May 8, 2008 | 10:48 PM
chance94z's Avatar
Need Help!!
I have a 91 305 tpi Z28, and I am having problems with the computer. Does anyone have a spare computer that will work with my car? I dont know if its the chip or the ecm itself so I am just replacing it all. It will run but the service engine soon light goes on and off. When it comes on it runs like crap and when it goes off it runs perfect. Any help would be appreciated.
Old May 10, 2008 | 08:48 PM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
Re: Need Help!!
Have you checked for trouble codes? It's pretty rare for a computer to die.
Old May 10, 2008 | 09:19 PM
chance94z's Avatar
Re: Need Help!!
Yeah, when we put it on the scanner it said ecm.
Old May 11, 2008 | 04:16 AM
83Firebird420's Avatar
Car: 87 GTA 120,000k, 90 CRX Si
Engine: 5.7 TPI, 1.6L 16 valve SOHC
Transmission: 700r4, 5spd std
Re: Need Help!!
in my experiance, i used a snap on scanner at my work. it said it wasnt able to comunicate with the ecu, or it was a faulty ecu. my snap on scanner i have at home is able to read the ecu just fine. so if u can get it scanned by a different shop. or one with an older scanner. u may find its not the ecu.
