How to gut the MAF??
Old Oct 28, 2001 | 08:57 PM
FIRECHICKEN's Avatar
Car: '89 Formula 350
Engine: 5.7L L98 TPI
Transmission: 700-R4 Automatic
Axle/Gears: 7.5 disc posi 3.23
How do you get the MAF apart to grind down the fins??
Old Oct 28, 2001 | 11:04 PM
Vader's Avatar
FC,
Do an archive search for MAF + modified + heat sink.
Then do a search for MAF + replacement...
Later,
Vader
If you want to beat the World, it might reach up and pull you down...
Adobe Acrobat Reader
Old Oct 28, 2001 | 11:27 PM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
What he is saying, is don't do it at all.
Old Oct 29, 2001 | 09:24 AM
BadSS's Avatar
You don't take it apart. Get a hacksaw, undo the blade, slip it through the MAF and reattach the blade. Saw away. Cut it close, but not so close you cut into the plastic housing. Any little bit sticking up can be ground down with a dremel. Be carefull and do not break the MAF wire in the "eye". I've made covers to go over the ends and seal them on with duct tape until I'm through with the mod.
I've found it to be beneficial even on "stock" 350s with AFPRs,, and even more help to more powerfull combinations.
Old Oct 29, 2001 | 12:13 PM
Fastcamaro87's Avatar
if u really want it to be a perfect job, take it to a machine shop after following BADDSS`s advice of taping up the ends of the eye that holds the wire, and have them mill out the fins, at the most they might charge you a few $$$ or if you want to send it to me and i can mill the out for ya..
87 IROC-z 305 TPI
Borg Warner T-5 fresh rebuild
10-bolt 3.73 Richmond gears rebuilt GM posi,
formerly BW 9-bolt w/3.45 gears(broke it)
Ported Plenum and Runners Homemade AFPR
ACCEL 8.8 wires, High output coil,and cap & rotor
Bosch platinum + 4 plugs
Ram Air w/ K&N filters,
MAF sensor screens removed, TB coolant bypass
Polyurethane tranny and torque arm mounts
Dynomax catback w/custom tips
K&N oil filter,Mobil 1 synth, Futura GLS Super Sport tires 265/50/15 rear and 235/60/15 front mounted on 86 monte carlo SS rims ,
400 sbc and a 6 spd in the works
Old Oct 29, 2001 | 05:28 PM
breathment's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Vader:
FC,
</font>
haha
- David
88' GTA 5.7L TPI MODS---&gt; air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT, Flowmaster 80 Series
http://www.geocities.com/david_angel_16
Mark_ZZ3
May 24, 2018 01:02 PM
BumpaD82
Feb 26, 2016 02:57 PM
racereese
Oct 3, 2015 03:46 PM
Ikes 91Z
LSX and LTX Parts
Sep 13, 2015 09:03 AM
