injector size for tpi 350 .040 over
Old May 11, 2008 | 02:28 PM
vasquezmrysvll's Avatar
Car: 1985 California Iroc
Engine: HSR ZZ4 0411 swapped
Axle/Gears: 3.23 posi
should i run 22lb or 24lb from a lt1? the engine is a 350 .040 over with a mild tpi profile cam. oh... and i need it to pass ca emissions . thanks
Old May 11, 2008 | 04:54 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: injector size for tpi 350 .040 over
With a mild cam and stock intake the 22lbs will work just fine.
You wont need 24lbs until you get over 400 HP and 5000 rpms. At that point you'll need to do custom chip tuning.
Old May 12, 2008 | 03:03 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
22s are fine. That extra 7 cubes for the .040 won't make a difference.
gta90
Sep 15, 2015 04:00 PM
NinjaNife
Aug 23, 2015 11:49 AM
wruiz
Aug 13, 2015 09:07 PM
Sanjay
Aug 12, 2015 03:41 PM
knight72
Aug 10, 2015 09:32 PM
