High rpm back fire?
Old May 13, 2008 | 11:42 PM
Raiden's Avatar
High rpm back fire?
I had an issue with my FMU and it was causing extremely high fuel pressures at idle. I fixed the FMU issue which was a chore! Now, my fuel pressure is 43.5 at idle and it increases through the rpm range with boost to 85psi as it should. Now, when I run through the gears, my car backfires @ 5k rpm. Anytime I get above 4500-5k, I"m getting a backfire and not just one. I have to pull my foot out of it, then it stops. I have changed multiple fmu settings from the lowest to the highest and no change. Still backfire's I tried increasing the fuel pressure from the afpr to 52, and nothing!
What gives?
Old May 13, 2008 | 11:57 PM
Raiden's Avatar
Re: High rpm back fire?
I forgot to add, when I have my car in idle, vacume gauge is reading a steady 15. When I put my car in drive, it drops to 12-13 as it always has thanks to my cam. Now, here's an interesting thing that is going on. Every so often, the car will loose vacume and it seems the car is loading up, then it corrects its self? It does not do it very often, once every 5-8 minutes only when it's in drive. I HATE MY CAR
Thanks for your help!
Old May 14, 2008 | 09:31 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
valve float
how old are your springs
also stock hei will not handle the r's
Old May 14, 2008 | 02:54 PM
Raiden's Avatar
Nope. My car was running fine until I put the smaller injectors in. I changed the injectors to the larger ones that I was running and it's still running like crap. I checked my valve lash and it's perfect. Your though process is on the same line of thinking as mine. Tomorrow, I'm going to check and replace plugs, wires, cap/rotor and check my coil.
Thanks for the comment and idea
Old May 16, 2008 | 01:34 AM
Raiden's Avatar
Turns out, my MDS box was the problem. My revlimiter is not allowing my Z to go above 5k. My ignition box is over 10 yrs old...time for a new one
eightsixseven
Dec 16, 2024 01:50 PM
specialized
Jun 18, 2022 09:26 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
