satsfactory oil psi?
Old May 14, 2008 | 12:27 AM
FireBirdKnight's Avatar
Car: 1985 TransAm
Engine: 5.0L TPI
Transmission: 700R4 auto
Axle/Gears: 3.27 BorgWarner
i have an 85 t/a was sitting for 2 yrs and the oil pressure at idle is about 25-27 lbs normally ive seen them in the 30's at a cruise it has oil psi of about 45
the oil is 2 years old 5w30 i know it needs to be changed
but is this acceptable oil psi readings? it just turned 100k
no blue puffs and no leaks
Old May 14, 2008 | 12:38 AM
tshack's Avatar
Car: 87 Z28
Engine: 89 tpi soon tpis big mouth & tubes
Axle/Gears: 3:43
Re: satsfactory oil psi?
That doesn't seem bad. my 87 LB9 get 30 at idle about 50 at cruise after it warms up. I don't know the mileage speedos way off. One of my squawks. but what do you want, I only have 350.00 in the poor beat Z28.
Old May 14, 2008 | 11:31 AM
Quick_Trans_Am's Avatar
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
That's decent pressure at idle. Changing your oil and filter it may perk it up a little. Once the filter gets too clogged, oil will flow through the filter bypass, causing unfiltered oil to circulate through the system.
Hotrodboba400
Dec 10, 2019 07:07 PM
Mdenz3
LSX and LTX Parts
Dec 10, 2015 11:18 AM
customblackbird
Oct 1, 2015 04:30 PM
eustodp
Sep 20, 2015 05:09 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
