help...READ IT
Old Nov 3, 2001 | 10:36 AM
86irocL98's Avatar
Car: 91 TA vert
Engine: 355
help...READ IT
does anyone know what kind of psi a tpi350 should have with 58cc heads and a compression ratio of around 9.5:1?
Old Nov 3, 2001 | 01:54 PM
Guest
Guest
Posts: n/a
Cam makes a difference too in what the reading will be. You should have over 150psi though, beyond that its a matter of how the engine was built.
Actually I just read your other post, 195psi is pretty impressive... Probably a small cam or not much overlap huh?
[This message has been edited by madmax (edited November 03, 2001).]
