What is this thing??
Old Nov 3, 2001 | 02:40 PM
86TpiTransAm's Avatar
Car: 1986 Trans Am, 1991 Firebird
Engine: 355 TPI, 3.1L V6
Transmission: 700R4 in both
I'm doing my engine swap this weekend and finding all sorts of new things I didn't know TPI had on them. I found this one particular item that I'm curious about what it is. I don't have a pic of it so I'll try my best to describe what it looks like. It's about the size of a fuel filter on our cars and it sits back on the drivers side of the intake in the VERY back next to the distributor cap. It sits vertical and has an L shaped looking pipe that goes into the intake. On the top of this item there is one single connector on it. Oh yeah, it's gold colored... if that helps any. What the heck is this thing?? Is it something that I should worry about replacing. If anyone knows anything please let me know. Thanks in advance.
1986 Trans AM
305 TPI
Well over 200,000+ miles (speedo/odometer non-funtional! Odometer reads 142,000)
4 Wheel Discs
9 bolt Borg Warner Rear (2.77's....oh joy) :P
Completely Stock
Current Project: upgrade to a 355 TPI, 6" rods, 9.7:1 Compression, Stock TPI ported, 24#/hr LTI injectors (cleaned and flowmatched), Hedman Shorty Headers, 3" cat back exhaust with flowmater, SBC 993 heads completely redone and modified for 1.6 RR, Comp Cams XE262-14 TPI Cam, Ed Wright Fast Chip, Holley AFPR, TPIS airfoil, MSD wires, MSD 6-AL Box, Hypertech hot coil!!
Old Nov 3, 2001 | 03:16 PM
SmokinZ28's Avatar
I belive that's you oil sending unit
Old Nov 3, 2001 | 03:29 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Look a little closer, if it's the oil sending unit it will be into the block, just behind the intake.
Old Nov 3, 2001 | 04:34 PM
rezinn's Avatar
These guys are right, that tells your oil pressure guage where to move. Replace it if your guage doesn't work, otherwise just leave it.
Old Nov 3, 2001 | 05:59 PM
This is NOT the oil pressure sending unit. I know where that's at. This is above that and sticks up ABOVE the intake right next to the distributor cap. A SINGLE connector is on top... one pin, not two. The bottom side has an L shaped pipe that comes down and goes into the back of the INTAKE.
Old Nov 3, 2001 | 08:19 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
<font face="Verdana, Arial" size="2">Originally posted by 86TpiTransAm:
</font>
i have an '86 t/a also. it is the oil pressure sending unit for the guage. you should also have another smaller one under it. silver. it is for the computer.
Old Nov 3, 2001 | 09:57 PM
<font face="Verdana, Arial" size="2">Originally posted by mrr23:
[/B]</font>
My mistake then. Thanks for the correction. The silver one is what I thought went to the guage. So the gold one is for the guage and the silver one below it is for the computer. Thanks
Old Nov 3, 2001 | 10:05 PM
Z03Z28's Avatar
Car: 92Z28,98LegacyGT,ZX9R,91 Z28,02 Z71
Engine: 350,307,2.5,900cc,5.0
Transmission: 700r4,4spd auto,700r4,4L80
Axle/Gears: 323,?,323,?,373
Are you talking about the black
round thing with the 2 vac hoses
one in the the top and the L shaped
one on the bottom?
Old Nov 4, 2001 | 11:46 AM
<font face="Verdana, Arial" size="2">Originally posted by Z03Z28:
one on the bottom?
</font>
Nope, this doesn't have any vacuum lines. Thanks for the help though. The thing I'm talkin' about is the sending unit for the oil pressure. I got it taken care of. Thanks!
morrow
Jan 13, 2024 12:29 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
TheExaminer
Aug 19, 2015 10:07 PM
Bob88GTA
Aug 18, 2015 03:31 PM
