compression
Old Nov 3, 2001 | 10:26 AM
86irocL98's Avatar
Car: 91 TA vert
Engine: 355
compression
on a 9.5:1 motor, how would 195 rounded psi be....?....help?
Old Nov 3, 2001 | 11:15 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
It think a litle high that would be about 12.24:1 psi
Here is how I figured it & why:
Room ATM is about 15psi, (actually 14.7psi) if you cut the volume in half that works out to be about 30 psi. But since we started at 15, you would only read 15.
Therefore if you take 195 - 15 = 180 & divide by 14.7 you would get 12.244897:1 compression.
It works out about right. By Riv is 10.5:1 and the compresion reads around 170psi of pressure.
so (psi-15)/14.7=compression:1
Just a guess though
John
G O D BLESS AMERICA
http://www.3rdgenformula.com
87 Formula 5.1 TPI Auto Modified (Yellow/Black)
87 Formula TPI (5 Speed) Yellow/Gray STOCK
14.8sec 1967 Buick Riviera
1990 Buick Riviera
83 Camaro
83 T/A
Old Nov 5, 2001 | 10:59 AM
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
Unfortunately, you can't directly calculate the compression ratio from the compression gauge reading. I have an 11:1 CR in my 355 (calculated using cc of heads and pistons) and my compression testing gave me 225 psi. I'd say 195 is probably closer to 9.5:1, but the duration of the cam also plays a part in the compression readings you'll get.
Greg Westphal
'87 IROC 355TPI/A4
FormulasOnly
Jul 23, 2018 08:47 AM
69GTOby
Apr 18, 2016 02:34 PM
Nervous2
Oct 8, 2015 10:53 PM
Jonas Earl
Sep 27, 2015 07:39 AM
WhteRbt
Sep 21, 2015 09:48 AM
