Are these the same???
Old Nov 6, 2001 | 12:51 AM
chevyboy07 91's Avatar
I have a set of '87 350 (L98) heads off a roller block and I want to port them and put them on my 92 Z. are they the same in design or does one have advantages over the other? Thanks...also casting #'s would be nice b/c I dont have the heads locally and cant check them.
Alex A. (aka chevyboy)
1992 Z-28 L98/1LE. Heritage Edition. SLP runners, gutted cats, SLP 3" cat-back & muffler. 3" flo-tech cut-out, SLP TB foil, K&N filter @ TB, 3.23 posi rear.
Old Nov 6, 2001 | 01:31 AM
JR4444's Avatar
I beleive that from 87 to 88 and up, they changed the bolt patern on the heads. I'm not 100% sure though.
88 Formula 350
Upper and Lower SuperRam, 1000 CFM Accel Throttle Body, ZZ4 cam, 24# Motorsport Injectors, Larger Gutted Mass Sensor, Homemade Cold Air induction, Custom Burned PROM, MSD 6a box, MSD Distributor, Accel SuperCoil, Taylor 8mm wires, TB Bypass, B&M shift Kit, 160* Thermostat, Flowmaster Muffler,
Old Nov 6, 2001 | 08:33 AM
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
They changed the intake bolt angle from '86 to '87 as my '87 has the newer bolt angle. The '87 heads probably have a different casting number since GM made some changes to the exhaust ports in '88 and who knows what else, but they'll still bolt right up. You can check casting numbers at www.mortec.com
Greg Westphal
'87 IROC 355TPI/A4
