Erratic Error Codes?
Old May 19, 2008 | 04:16 PM
19CAMARO85's Avatar
Car: 1979 Z28 / 1990 RS
Engine: Matching 350 / 305 TBI
Transmission: Built TH350, 3000 Stall / 700r4
I recently have started working on my car to get it redone and lookin good. well ever since i have had the car the check engine light has always been on. i assume because of bad sensors and a hack job of some wires i grounded the terminal to manually read my codes to find out whats going on and the code stated: Erratic or intermitted at times. What does this mean i need to do so that i can start reparing my camaro.? Please help me. there are alot of things that i need to fix but i can read my codes do to this problem. thanks
Old May 19, 2008 | 08:45 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: Erratic Error Codes?
What was the code? The number?
Old May 19, 2008 | 08:48 PM
19CAMARO85's Avatar
well i grounded the diagnostic terminal since i didn't have a scanner to read the codes with. When i tried to get the code 12 first all i got was the persistant flashes that = the erratic code... so it really doesn't have a #
Old May 19, 2008 | 09:39 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
I had this issue with a conversion to my 727 ecu (from a vette) and it was a dead ecu.
Look into that, swap ecu's from someone else if you can. My car ran even without a chip in it, it did not run any different either, The computer was in some sort of backup mode off a hardcoded limp home mode.
Old May 21, 2008 | 04:03 PM
19CAMARO85's Avatar
hmm so i should just try another computer? think that could change/improve the way it runs? thanks man
Old May 21, 2008 | 05:52 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
It's worth the try if you can swap one out as a test.
Falcon50
Aug 22, 2020 03:26 PM
Luigytico09
Oct 1, 2015 08:46 AM
thejimsterz28
Sep 30, 2015 08:52 PM
3rdgenparts
Sep 28, 2015 10:47 PM
ironbmt
Sep 27, 2015 06:00 AM
