Injector Help Please!
Old Nov 6, 2001 | 08:58 PM
91Firecrow305TBI's Avatar
My girlfriend has a pretty hopped up 350-383 motor with 58cc Edelbrock heads, and a high lift/duration cam. She has the stock 305 injectors right now, we need more, and have the option of buying either 24 or 36# injectors.
Would 36# be too much? or would it be the right ones to go for? Also is Bosch better than Accel?
Thanks ahead of time,
Clint
Old Nov 7, 2001 | 08:57 AM
Desert86Roc's Avatar
What is "hopped up"? What Eprom programming is being used? Is there an AFPR? Need more info.
Old Nov 7, 2001 | 09:47 AM
Mojo's Avatar
I would think you could easily get away with a set of Ford Motorsport 24# injectors. About $200 through summit. They are rated at 36# of fuel pressure instead of 40+, so they flow just a bit more than 24#. I used stock GM 24# injectors in my 408 for years, but I had to set the pulse width way too high for them to operate properly on the top end. I switched to Ford Motorsport 30# injectors last year, and they're about perfect. Of course, I probably have a bit more motor than your GF. Who is doing your tuning?
408cid 1985 Corvette
http://www.mojosgarage.com
92-Formula
Dec 12, 2015 10:34 PM
rubyred88
Sep 17, 2015 02:19 PM
thejimsterz28
Sep 15, 2015 04:37 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
