anyone ever mount a fuel pressure sender engine?
Old May 19, 2008 | 08:36 PM
Bobby_80s's Avatar
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
anyone ever had to connect a fuel pressure sender for a permanent fuel pressure gauge to the fuel rail?
how did you do it?
Old May 19, 2008 | 10:11 PM
Quick_Trans_Am's Avatar
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
Re: anyone ever mount a fuel pressure sender engine?
You can buy a kit at summit racing. More than likely you'll want the electronic one, pricey, but you don't have to worry about fuel ever getting inside the cab area. If memory serves, the sender will connect right to the valve on the fuel rail, and you just wire it up. Here's a link to one:
http://store.summitracing.com/partde...5&autoview=sku
Old May 19, 2008 | 10:18 PM
Bobby_80s's Avatar
Axle/Gears: no idea
I already purchased the digital cyberdyne gauge.
i need some kind of connector or make one using 3 different metal pieces
the valve stem schrader valve is 7/16 fine threads
the fuel sender has 1/8 threads
i need something in between to connect them
Old May 19, 2008 | 10:20 PM
I see now. That to me would be a simple trip to the hardware store for an adapter.
Old May 19, 2008 | 11:02 PM
Bobby_80s's Avatar
Axle/Gears: no idea
The problem is the part that connects to fuel ral schrader valve. theres a alittle stem in the center to push in to release the fuel pressure into the line to the sender
know what i mean?
Old May 20, 2008 | 08:39 AM
Mongoose's Avatar
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
Just remove the schrader valve with a valve stem tool like you would a tire.
Old May 20, 2008 | 02:11 PM
Bobby_80s's Avatar
Axle/Gears: no idea
im hoping i dont have to do that but its definately an option
anyone know the thread type that screws into the fuel rail?
Old May 20, 2008 | 03:24 PM
Mongoose's Avatar
Car: 90 Formula
That's the only way you'll get a reading on the gauge. The fitting on the rail is an AN fitting. I used a 90 degree swivel and then a -4AN braided line up to a -4AN to 1/8NPT adapter and then attached the sending unit in a bracket on the firewall that the sending unit screwed into and then to the gauge in a pillar pod. I'm using an Auto Meter Sport Comp 2 gauge.
Old May 20, 2008 | 04:17 PM
Bobby_80s's Avatar
Axle/Gears: no idea
ok thank you,
where did you purchase these items? all in one place i hope? or other place i could buy these like home depot or just strickly an auto place?
and did this ground the sender automatically when screwed in?
when i say items i mean just the parts that connect the sender to the fuel rail
Old May 20, 2008 | 05:47 PM
Mongoose's Avatar
Car: 90 Formula
I got everything at a local speed shop. As for the grounding there is a ground wire in the harness for the Autometer gauge so I'd have to say no to the screwing in of the sender. You may be able to locate these fiting parts at a hardware or plumbing supply house but since they will be exposed to fuel you may want to stick with automotive grade stuff. Summit or jegs will have everything you need from either Russell or Aeroquip.
Old May 20, 2008 | 06:15 PM
Bobby_80s's Avatar
Axle/Gears: no idea
alright thank you very much
Old May 20, 2008 | 06:33 PM
Bobby_80s's Avatar
Axle/Gears: no idea
if i remove the schrader valve is it able to screw back in as is?
Old May 21, 2008 | 01:58 AM
Bobby_80s's Avatar
Axle/Gears: no idea
vavle stem tool? cant i just use a wrench?
Old May 21, 2008 | 02:36 AM
Bobby_80s's Avatar
Axle/Gears: no idea
nevermind i have my answer tahnks for all your help
92camaroJoe
Jul 29, 2023 07:57 PM
R3500
Aug 17, 2015 12:16 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
