!!I need help with TPI intake!!
Old Nov 7, 2001 | 09:02 PM
SS-IROC-Z's Avatar
I have a 86 TPI intake.How hard would it be to make it fit a 87-88 350 TPI motor.And is any one selling one.
Old Nov 8, 2001 | 12:21 AM
Guest
Guest
Posts: n/a
Its not too bad, you can just elongate the holes. One area by a bolt will get a little on the thin side but it will be ok if you are careful. I cant remember which hole it is offhand. If you have the means, machining a flat area for the bolt head and cutting that down a little will help, because the bolts will stick up some and interfere with the runners a little bit when you are putting them on.
1992rs/ss
Jan 31, 2025 05:10 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
masonta
Aug 31, 2015 10:14 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
