please help
Old May 21, 2008 | 03:31 PM
white86irocz's Avatar
please help
i have a 89 iroc z my tach is skipping ????????? what can be causing this i replaced the coil and that didn't help please help!!!!!!!!!!
Old May 22, 2008 | 10:54 AM
89IROKCONVERT's Avatar
Re: please help
does that mean the engine is missing or is it just the tach if its missing i would change the ignition module if its no it sounds like you need a new tach.
Old May 23, 2008 | 09:19 PM
Re: please help
the engine is skipping and the tach has a jump to it. it jumps about 200 to 300 rpms but the engine doesn't change. i replaced the ignition control module, spark plugs wires and the cap and rotor and the motor is still skipping what do i do??????????????
Old May 25, 2008 | 07:37 PM
Re: please help
you could have a bad plug a bad wire or a bad pickup go out there at night and see if any thing arks if its not that the only things left are a wiring problem or a bad computer.
Old May 25, 2008 | 08:05 PM
1fastam's Avatar
Car: 1991 transam
Engine: 305 30 over long tubes into 3" y
Axle/Gears: 4:10
Re: please help
make sure the plug wires arent crossed up,unplug the tach wire and replug it. look for simple things first,later jimmy
