Need Everyones opinion
Old Nov 8, 2001 | 09:00 PM
1986CamaroIROC-Z's Avatar
I was lookin through my Jeg's catalog and saw an Accel Superram for the TPI camaro. I have a 1986 305 TPI and was wondering if this setup is a good item to purchase. I would onyl need the PLenum and Runners I assume since i already own the Edelbrock baseplate. It is 760 dollars, and I was wondering if its better just to port my plenum and baseplate, and get SLP runners and port them. All responses are greatly appreciated.
Old Nov 8, 2001 | 09:09 PM
JR4444's Avatar
Well, most people on this board don't like the superram, for what ever reason. I personally think that it would not work well with a 305. On the lingenfelter website they reccomend only using the superram on 350 and up engines.
88 Formula 350
Upper and Lower SuperRam, 1000 CFM Accel Throttle Body, ZZ4 cam, 24# Motorsport Injectors, Larger Gutted Mass Sensor, Homemade Cold Air induction, Custom Burned PROM, MSD 6a box, MSD Distributor, Accel SuperCoil, Taylor 8mm wires, TB Bypass, B&M shift Kit, 160* Thermostat, Flowmaster Muffler,
Old Nov 8, 2001 | 09:11 PM
86Z28TPI's Avatar
Don't bother unless you are planning on getting a 350 or bigger. I have the same car with a 305 and the EXPENSIVE mods aren't worth it for the small engine. No matter what you do to a 305, it's never gonna set the world on fire.
Pac J
May 17, 2020 10:44 AM
skinny z
Oct 5, 2015 06:23 PM
Dragonsys
Sep 25, 2015 03:51 PM
Twinn Engines
Sep 25, 2015 06:27 AM
Twinn Engines
South East Region
Sep 25, 2015 06:25 AM
