need some help
Old May 22, 2008 | 01:25 PM
everythingtech's Avatar
Car: 1987 Iroc
Engine: 5.7 chipped, cai, true dual exhaust
Transmission: 700r4 no 3rd or 4th shift kit B&M
need some help
I am about to start a swap and need to move my car. I went to do it and it died. I ran out of gas. Easy fix right? not so much. I put 4 gallons of gas in the car and it still wont start. I sprayed a very little bit of gas in the intake, and it fired right up... then died.
Questions:
Should i hear the fuel pump come on when i turn the key on? I dont hear anything.
I read up on this, and i heard that the oil pressure will send a charge to the fuel pump.. While turning over, my oil pressure will go up to normal, still no start.
I also replaced the battery because it sat for a long time, but that was after all of the above while on a jump.
I am not the original owner, and there is a lot of stuff disconnected under the hood. I know they took the a/c out..
Does anyone have a diagram of where to look if you talk about relays?
Also i have ran into this before and the simple answer was check the distributor wiring. That connector got borken and the previous owner just zip tied it once connected.
Thanks in advance, and sorry if this is redundant to other threads. I am just lost at this point...
Old May 23, 2008 | 10:16 AM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
Re: need some help
You should hear the fuel pump when the key is turned to "run" position. Do a search for the fuel pump pin on the ALDL connector. I believe you can supply 12v to that pin and power the pump long enough to move car; assuming the fuel pump isn't dead..
Old May 23, 2008 | 10:33 AM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
Re: need some help
Here's a pic.
Old May 23, 2008 | 10:34 AM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
Re: need some help
Try again...
Old May 23, 2008 | 10:37 AM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
Re: need some help
Not sure why pic isn't "clickable", but here's the link:
https://www.thirdgen.org/forums/tpi/...+pin+aldl+pump
I give up... Do a search for it..
