Arrghh...Do I have to get new injectors?
Old Nov 9, 2001 | 07:09 PM
ChevyKen's Avatar
Car: 86 IROC Convt
Engine: 305TPI
Transmission: TH700R4
As you may have seen on the other post I made, I am replacing the O-rings on the injectors before putting them back in.
Now, when I started looking at them, I noticed that several of them had cracks and even missing pieces around the "edge" on the brown cap around the bottom end of the injector. That is the egde that the o-rings are "resting" agains, - is this critical? Will it leak fuel if they are installed like that? Do I need to buy all new injectors?
Ken
1986 IROC-Z Conv't
- White Gauges, 17x9.5 TT II rims w/275/40x17" F1s, 1.5" Jamex Lowering Springs, BMR stb, Lakewood APR, PST suspension parts, Edelbrock Trailing Arms, KYBs, Edelbrock RPM Cat-Back, Edelbrock JHC Headers, Catco, World Products Heads, CompCam, SLP runners, Ported Plenum, K&N, Airfoil +polished/billet dress-up stuff
ChevyKen's Cars
Administrator @ ChevyWorld.net
Old Nov 9, 2001 | 08:15 PM
Guest
Guest
Posts: n/a
Nope, they are fine. They are actually called pintle protectors, tho some claim they help atomize the fuel... I seriously doubt it but anyways...
You can get new ones for less than a buck a piece, NAPA should have them.
Old Nov 9, 2001 | 08:28 PM
ChevyKen's Avatar
Car: 86 IROC Convt
Engine: 305TPI
Awesome!!
So, how do they come off? Do I just pull them?
Thanks man!
Ken
Old Nov 9, 2001 | 11:07 PM
Guest
Guest
Posts: n/a
Yea, theres some small tabs that fit into a shallow groove in the injector body, if you have new ones it might be easier to carefully break/cut the old ones off rather than try to save them. Be real careful not to mess up the pintle, then you will be getting new injectors.
Old Nov 10, 2001 | 11:18 AM
ChevyKen's Avatar
Car: 86 IROC Convt
Engine: 305TPI
I got'em off!
Thanks a lot for your help man!
Ken <~~~~~*off to NAPA*
92-Formula
Dec 12, 2015 10:34 PM
rubyred88
Sep 17, 2015 02:19 PM
thejimsterz28
Sep 15, 2015 04:37 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
