someone take a look at my cts results????
Old May 24, 2008 | 11:46 AM
Bobby_80s's Avatar
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
just wanted to have a second pair of eyes on my voltage and ohm readings across my coolent temp sensor for the ecm on my v8 305 tpi 1986
all readings were made when engine was cold.
ohm reading 4300 which from the chart is somewhere in the 60 degrees range i believe
voltage across the wiring harness disconnected from the sensor is 5v with ignition key turned
plugged in i read 2.65v across the sensor
does this sound like a propper working coolent temp sensor?
i'm just trying to rule it out as a problem with my high idle
its brand new and about a yr old. car has barely been driven 10miles since i put it in.
i dont have readings when the car is hot.
can anyone just give their two cents on my findings. it seems to be up to specs for a cold sensor.
Old May 24, 2008 | 05:27 PM
Vader's Avatar
Re: someone take a look at my cts results????
Your resistance looks about right.
Old May 24, 2008 | 05:44 PM
Bobby_80s's Avatar
Axle/Gears: no idea
yea i thought so i was lookign at the same chart, anybody have an idea if the voltage readings with the sensor connect is correct?
Falcon50
Aug 22, 2020 03:26 PM
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
Thornburg
Oct 6, 2015 12:04 PM
gord327
Oct 3, 2015 01:25 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
