Help putting in headers...
Old May 24, 2008 | 05:57 PM
WhiskeyChick's Avatar
Car: 1987 Trans Am GTA
Engine: 305 V8
Transmission: 5spd
Axle/Gears: 9bolt
I need help. I got the passenger side manifold out no problems, just a little PB blaster.
The drivers side on the other hand....
Oh and I have a 87 GTA, with cruise, Air conditioning, power steering, blah blah blah. Needless to say I have not a whole lot of room to work.
Here is the issue, I cut all my air tubes off cause i have junked the smog stuff, and now I have this bolt with a bracket that I cant figure out how to get it off.
The bracket runs behind the power steering pump, but I can't follow it. and it wont budge. And I cant get the manifold off with out getting that stud off, which is behind the bracket.... I hate GM.
anyone else run into this?
Old May 24, 2008 | 06:30 PM
Engine: 305 V8
Transmission: 5spd
Axle/Gears: 9bolt
Re: Help putting in headers...
nevermind, helps if you look under your car...
Jake_92RS
Jan 28, 2020 10:37 PM
dyeager535
Aug 28, 2015 08:10 AM
michealleger
Aug 26, 2015 03:29 PM
87 camaro iroc
Aug 20, 2015 07:47 AM
Fronzizzle
Aug 9, 2015 01:15 PM
