vss/wiring/tpi swap queston
Old Nov 10, 2001 | 03:47 PM
Momar's Avatar
I have an 87 tuned port setup that I plan on puting on a 350 and I want to convert it to speed density. I have the electric spedometer out of an 87 and have heard that the vss for the speed density is different. I was wondering if they are actually different. If they are I was wondering if it is possible to set it up so that I can use the newer vss and my spedometer still work properly.
Ben
Old Nov 10, 2001 | 09:36 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Yes, they are different. The 7165 ECM operates on 2000 pulses The 7730 is 4000.
You will need to get a VSS from a SD car.
Then the two wires from it feeds into the ECM direct(not thru a buffer) the output from the ECM then drives the speedo and the cruise control.
Chronologically challenged. But still kicking!
'92 CAMARO RS
305 TBI 5/spd (now TPI)
B4C Alt.
Cam change:TRW 198/210 ,450/.460 114 LSA
Stock TBI manifolds
'85 IROC Ex.
14.94-92.00 mph
SPDC base and "350" Vortec coming soon!
'69 camaro-BB/Lenco,1050 dominators, /Pump Gas/no drugs 8.97-150+/3200lbs.
SoCal Thirdgen F-Bodies
Old Nov 11, 2001 | 04:12 PM
crucial's Avatar
BZZZZT!
The VSS itself will work with both SD and MAF. I have a "MAF car" VSS in my SD car and it works juust fine.
Momar, that VSS will work just fine with the speed density computer.
1991 Z28 5.7 TPI
ZZ4 heads, ZZ4 cam, Harland Sharp roller rockers, Accel base, SLP siamesed runners, 52MM SLP Throttle Body, Hooker Headers, Flowmaster catback, MSD6A ignition, Home made ramair system, aluminum driveshaft, WC 5-speed etc
E Rod
Aug 28, 2015 05:17 AM
theshackle
Aug 22, 2015 06:52 PM
Hello, Michael
Aug 20, 2015 03:19 PM
jharrison5
Aug 19, 2015 05:53 PM
355sbcTPI
Aug 19, 2015 04:38 PM
