Porting Plenum
Old Nov 11, 2001 | 07:48 PM
HotZ's Avatar
Porting Plenum
I needed help on how to port my plenum. Somebody said there was a tech thing on it. If anyone could help me I would appreciate it.
Old Nov 11, 2001 | 08:50 PM
nblanchard's Avatar
I will be doing my plenum soon. Here are some of the htings i was told.
1 When porting behind the throttle body mating surface, be careful when grinding down the side edges. The casting is a poor design, and if you grind too much, you could go right through. When grinding, listen for a ringing tone, or tinny tone... this will be an indicator that you have reached your limit.
2 I will be lining up the gasket to the bolt holes and gasket matching the port holes. I am not sure if that what others do.
3 Maybe try smoothing as much of the cast surface as you can.
1988 Pontiac Trans Am GTA L98 5.7L, Black on Black with 114,000kms.
Best ET 14.559 @ 95.25MPH
Custom 3" Stainless Exhaust Y-Pipe back (High flow Cat and Flowmaster Mufler)
Old Nov 11, 2001 | 09:45 PM
breathment's Avatar
its actualy alot easier once u get in there, your start to realize what needs to be ported and stuff, thats what happend to me anyways. good luck
- David
88' GTA 5.7L TPI MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT, Flowmaster 80 Series Muffler added to Unkown CatBack, Ported Intake
http://www.geocities.com/david_angel_16
Old Nov 12, 2001 | 07:14 AM
RCR's Avatar
RCR
Car: '84 Fiero ('01 GA interior)
Engine: '96 4.0 Aurora
Transmission: '96 4T80E
There's some stuff on my page: http://members.home.net/rcrabine/porting.html and on Dan Burk's page: http://www.isthq.com/~dan/fcar.html and a tech article on the intake, which applies to the plenum here: https://www.thirdgen.org/newdesign/t...meseport.shtml
Old Nov 12, 2001 | 10:26 AM
gravitar's Avatar
I had never ported anything before, but once I got going it seemed pretty intuitive. I don't know if its mentioned anywhere, but your best bet is to use a "NF burr" for the porting, because it doesn't load up AT ALL with aluminum.. I had much poorer results with steel burrs and grinding stones!
Old Nov 12, 2001 | 10:58 AM
1986CamaroIROC-Z's Avatar
SO, after portin the TPI manifold, and plenum, runners, you will lose torque down low and gain it up top, since u said it felt slower out of the gates. R there any good mods that add HP, but dont sacrifice torque.
Old Nov 12, 2001 | 11:57 AM
SMURFN' Z28's Avatar
Car: 1994 Jeep Wrangler
i dont know about you guys, but on every TPI car i have owned i had more low end torque than i knew what to do with.
Bone stock blue 85' Z28 42k original miles.
*previous car: lightly moded 89' Formula 350
Reid Fleming
Oct 10, 2015 09:56 PM
toronto formula
19
Oct 6, 2015 12:27 PM
bplessy
Sep 30, 2015 12:14 PM
