Which rockers for ED 6085s?
Old Nov 11, 2001 | 09:28 AM
DFI79MC's Avatar
Car: 79 Monte Carlo
Engine: 406
Transmission: 2004-R
Axle/Gears: Phord 9 inch/3.90
Later this winter or early spring i am going to put on my mildly worked Edelbrock 6085s. I am happy with the cam lift I have so I am going to use 1.5 rockers. Now my question is, which roller rockers am I limited to because of the centerbolt valve covers? Are there alot of options? What are you guys running with these heads? Responses would be greatly appreciated. Thanks
1979 Monte. 88 TPI, .30 over 89 350. SLP, Accel, TPIS, Comp Cams just to name a few.
Old Nov 11, 2001 | 12:49 PM
Ski89Z28's Avatar
Well I'm not much help, sorry, cause I used the Crane Cam Gold ones for center bolt valve covers. Very expensive!
I know other guys here have used different ones but I can't remember which ones.
Hopefully this put it to the top again and someone will answer it for you.
Good Luck!
89 IROC 350 Auto
MSD 6AL
Custom DUAL Exhaust
Edelbrock Performer 6085 Aluminum Heads
ZZ9 Cam
TPIS Level 5 Chip
And Free mods.
(stock intake, runners and suspension)
13.879 @ 98.90 mph (with 2.77 gears!)
Moderator of http://www.iroczone.com
Old Nov 13, 2001 | 01:58 AM
poncho9789's Avatar
You can run pretty much any rrs you want to if you are willing to do some modifying the stock valve covers. You take the support inside that is closer to the intake you cut out the the support that is parallel to the gasket surface. If you cut that longer side out you will have no problem running any rocker you want to just not shaft mount.
Mutillator
Exterior Parts for Sale
Jan 2, 2016 06:44 PM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
New2Chevy
Sep 28, 2015 12:35 AM
Billyadams
Sep 22, 2015 08:25 AM
ericjon262
Sep 11, 2015 06:07 PM
