egr removal
Old Nov 11, 2001 | 11:25 PM
pontiacpete's Avatar
egr removal
hi just wanted some advice on removing the egr valve and blocking it off will the ecm go into limphome mode?
Old Nov 11, 2001 | 11:38 PM
Vader's Avatar
Pete,
It may not revert to the backup fuel and spark, or "Limp Home" mode, but you'll probably get that nasty yellow light on your dash staring you in the face on the highway. Even the TBI cars have some diagnostics for the EGR, through the MAP sensor change when the valve is commanded open.
Later,
Vader
If you want to beat the World, it might reach up and pull you down...
Adobe Acrobat Reader
Old Nov 12, 2001 | 08:12 PM
MONTYR1's Avatar
I don't know about removal but my egr valve was leaking exhaust and it had triggered off another scensor, to me it seems like everything works as a system, so it may not scence your egr but the ecm may pick up something else. Good luck
Old Nov 13, 2001 | 04:00 AM
thanks for reply i will leave things standard to save me from that dreaded yellow light appearing
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Fronzizzle
Sep 8, 2015 12:10 PM
Stryker412
Sep 7, 2015 09:11 AM
rjcme
Sep 5, 2015 01:23 PM
