trick flow heads with stock tpi intake
Old May 28, 2008 | 06:46 PM
billybird's Avatar
Car: 89 Formula
Engine: LB9 TPI
Axle/Gears: 3.73(coming soon)
will the trick flow 23 heads for "89 with center bolt valve covers fit the tpi intake bolts
Old May 28, 2008 | 07:05 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Re: trick flow heads with stock tpi intake
Yes. I have it on my firebird with Center bolt valve covers. If using the stock covers, you will need to modify the inside bracing.
Old May 28, 2008 | 07:15 PM
billybird's Avatar
Car: 89 Formula
Engine: LB9 TPI
thx for the reply man...really?
maybe should i get there valve covers?
1992rs/ss
Jan 31, 2025 05:10 PM
Sanjay
Aug 12, 2015 03:41 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
marcusaw
Aug 10, 2015 08:13 AM
